Refinishing 42-327
Medium Walnut Tone Finish will match the original color well - and, unlike other Tone Finish colors, the Medium Walnut color isn't loaded with pigment so it won't look like paint after three coats.
But try to apply no more than two, as successive coats will make the cabinet look darker and more reddish.
If you want it to look as it did originally, use gloss instead of matte.
You will need to apply clear lacquer when done with the Medium Walnut and black. Again, gloss was the original finish.
Oh, next time, don't rely on sanding to strip a cabinet - use a chemical stripper, or a 50/50 mix of acetone and lacquer thinner. Use thick rubber gloves and do this work outdoors! The veneer on a cabinet is quite thin and it is easy to sand right through to the substrate if you aren't careful. Keep all sanding to a minimum - in fact, don't sand at all if you can keep from it.
Refinishing 42-327 - by Vic Gibson - 07-16-2013, 03:20 PM
RE: Refinishing 42-327 - by Ron Ramirez - 07-16-2013, 04:23 PM
RE: Refinishing 42-327 - by Vic Gibson - 07-16-2013, 04:39 PM
RE: Refinishing 42-327 - by Arran - 07-17-2013, 01:04 AM
RE: Refinishing 42-327 - by Vic Gibson - 07-17-2013, 09:01 AM
RE: Refinishing 42-327 - by Arran - 07-17-2013, 11:15 AM
RE: Refinishing 42-327 - by Ron Ramirez - 07-17-2013, 11:16 AM
Philco 91 Restore Code ??
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
Restoring Philco 96
There are currently 2049 online users. [Complete List]
» 2 Member(s) | 2047 Guest(s)
