Zenith R-5-312
Hi:
What would you use clean the dial face of this radio (with something that is around the house)? It is very dirty andI dont want the printing to come off.
Thanks, Buzz
Zenith R-5-312 - by Buzz - 07-16-2013, 08:28 PM
RE: Zenith R-5-312 - by morzh - 07-16-2013, 09:41 PM
RE: Zenith R-5-312 - by Buzz - 07-16-2013, 10:15 PM
RE: Zenith R-5-312 - by Arran - 07-17-2013, 01:23 AM
There are currently 9632 online users. [Complete List]
» 2 Member(s) | 9630 Guest(s)
