Boat Anchor?
No phono any idea what the last item in the first set of pictures with the two small coils? The other problem is there doesn't seem to be any documentation for this unit don't know if the tubes are in the right sockets?
Boat Anchor? - by Eric - 07-17-2013, 08:23 PM
RE: Boat Anchor? - by jerryhawthorne - 07-17-2013, 08:55 PM
RE: Boat Anchor? - by Eric - 07-17-2013, 10:32 PM
RE: Boat Anchor? - by Eric - 07-18-2013, 11:12 AM
RE: Boat Anchor? - by Chuck Schwark - 07-18-2013, 11:40 AM
RE: Boat Anchor? - by Eric - 07-18-2013, 09:49 PM
RE: Boat Anchor? - by Eric - 07-18-2013, 09:50 PM
RE: Boat Anchor? - by Electrothaumaturgist - 07-18-2013, 10:13 PM
RE: Boat Anchor? - by Eric - 07-18-2013, 11:07 PM
RE: Boat Anchor? - by BrendaAnnD - 07-18-2013, 11:34 PM
RE: Boat Anchor? - by Arran - 07-19-2013, 04:29 AM
RE: Boat Anchor? - by BrendaAnnD - 07-19-2013, 05:28 AM
RE: Boat Anchor? - by Ron Ramirez - 07-19-2013, 08:30 AM
RE: Boat Anchor? - by DeckApe - 07-19-2013, 09:46 AM
RE: Boat Anchor? - by Eric - 07-19-2013, 09:57 AM
RE: Boat Anchor? - by Arran - 07-20-2013, 02:45 AM
RE: Boat Anchor? - by Eric - 07-20-2013, 05:57 PM
RE: Boat Anchor? - by oldgoaly - 07-21-2013, 12:52 PM
RE: Boat Anchor? - by Eric - 07-21-2013, 01:36 PM
There are currently 7828 online users. [Complete List]
» 3 Member(s) | 7825 Guest(s)
