370 Chairside
It's certainly growing on me. I like it and thanks for the great shot of the label. Perhaps someone with better skills than me in photoshop would finish off the missing corners and post in the download section of the Phorum. My 112 is missing that label. Interesting that Norman used the same beaded molding on the chairside and 112 console designs.
Jerry
370 Chairside - by RoyG - 07-17-2013, 04:45 PM
RE: 370 Chairside - by 7estatdef - 07-17-2013, 05:53 PM
RE: 370 Chairside - by RoyG - 07-17-2013, 06:14 PM
RE: 370 Chairside - by jerryhawthorne - 07-17-2013, 07:18 PM
RE: 370 Chairside - by 7estatdef - 07-17-2013, 09:33 PM
RE: 370 Chairside - by Arran - 07-18-2013, 03:13 AM
RE: 370 Chairside - by Ron Ramirez - 07-18-2013, 05:30 AM
RE: 370 Chairside - by RoyG - 07-18-2013, 12:53 PM
RE: 370 Chairside - by Ron Ramirez - 07-18-2013, 12:54 PM
RE: 370 Chairside - by RoyG - 07-19-2013, 12:23 PM
RE: 370 Chairside - by klondike98 - 07-19-2013, 12:48 PM
RE: 370 Chairside - by jerryhawthorne - 07-19-2013, 02:12 PM
RE: 370 Chairside - by 7estatdef - 07-20-2013, 08:45 PM
Philco 91 Tuning Condenser
