Help identifying this phonograph? E1764 or E1765 from 1957?
Does it have a radio in it as well or just the phonograph?
RE: Help identifying this phonograph? E1764 or E1765 from 1957? - by Arran - 07-20-2013, 06:27 AM
Philco 91 Tuning Condenser
There are currently 7082 online users. [Complete List]
» 3 Member(s) | 7079 Guest(s)
