Help identifying this phonograph? E1764 or E1765 from 1957?
J2K Wrote:I'm going to plug it in and see if it works tomorrow.
[Image: http://i326.photobucket.com/albums/k420/...g~original]
This is the worst thing you can do to a piece of vintage electronic equipment, because it is a big gamble. It may work...it may smoke...it may trip a breaker. Or it could even catch on fire.
Vintage electronics should be thoroughly checked by someone who knows what to look for (bad electrolytic capacitors which should always be replaced before applying power, any tar or wax seeping from power transformers) before power is applied.
http://www.philcoradio.com/tech/plugin.htm
http://www.antiqueradio.org/powerup.htm
But if you're determined to really plug it in and see what happens...all I can do is quote Clint Eastwood:
...You've gotta ask yourself a question. Do I feel lucky? ...Well, do ya, punk?
RE: Help identifying this phonograph? E1764 or E1765 from 1957? - by Ron Ramirez - 07-20-2013, 07:53 AM
Philco 91 Tuning Condenser
