  • 2 Vote(s) - 4.5 Average
47-1230 Capacitors
Different types of caps have different strengths and weaknesses:
Disc ceramics are very good for RF bypasses, but unless they are NPO (COG) temperature stable types, their capacitance value may vary greatly with temperature and applied voltage.
Silver micas are typically used in RF tuned circuits as their capacitance value is stable with temperature and over time. Disadvantage is that they are somewhat expensive.
Film types are available in larger values and typically used as low frequency bypasses and coupling caps. Not the best choice for very high frequency RF as they have higher parasitic inductance than ceramics or micas.
Your radio operates at FM broadcast frequencies (88-108 MHz) so the RF caps can be more critical. If it were my radio, I would leave the low value caps alone for now, as the original caps are certainly either ceramic or mica. They are quite reliable and replacing them in the FM front end may cause problems with oscillations and instability.
47-1230 Capacitors - by Warren - 07-03-2013, 02:19 PM
RE: 47-1230 Capacitors - by exray - 07-04-2013, 06:27 AM
RE: 47-1230 Capacitors - by morzh - 07-04-2013, 11:26 AM
RE: 47-1230 Capacitors - by codefox1 - 07-04-2013, 11:38 AM
RE: 47-1230 Capacitors - by Warren - 07-04-2013, 06:15 PM
RE: 47-1230 Capacitors - by Mondial - 07-04-2013, 06:28 PM
RE: 47-1230 Capacitors - by Warren - 07-04-2013, 07:07 PM
RE: 47-1230 Capacitors - by Mondial - 07-04-2013, 07:54 PM
RE: 47-1230 Capacitors - by morzh - 07-04-2013, 08:00 PM
RE: 47-1230 Capacitors - by Mondial - 07-04-2013, 08:15 PM
RE: 47-1230 Capacitors - by morzh - 07-04-2013, 09:04 PM
RE: 47-1230 Capacitors - by Warren - 07-04-2013, 10:51 PM
RE: 47-1230 Capacitors - by morzh - 07-05-2013, 12:20 PM
RE: 47-1230 Capacitors - by Warren - 07-08-2013, 01:46 PM
RE: 47-1230 Capacitors - by morzh - 07-08-2013, 08:11 PM
RE: 47-1230 Capacitors - by Warren - 07-08-2013, 08:44 PM
RE: 47-1230 Capacitors - by Warren - 07-19-2013, 01:45 PM
RE: 47-1230 Capacitors - by Chuck Schwark - 07-19-2013, 02:12 PM
RE: 47-1230 Capacitors - by Warren - 07-19-2013, 02:28 PM
RE: 47-1230 Capacitors - by codefox1 - 07-19-2013, 03:02 PM
RE: 47-1230 Capacitors - by Warren - 07-19-2013, 08:24 PM
RE: 47-1230 Capacitors - by BrendaAnnD - 07-19-2013, 09:18 PM
RE: 47-1230 Capacitors - by Warren - 07-19-2013, 11:37 PM
RE: 47-1230 Capacitors - by BrendaAnnD - 07-20-2013, 12:59 AM
RE: 47-1230 Capacitors - by Mondial - 07-20-2013, 09:02 AM
RE: 47-1230 Capacitors - by Warren - 07-20-2013, 05:02 PM
RE: 47-1230 Capacitors - by Mondial - 07-20-2013, 11:46 PM
RE: 47-1230 Capacitors - by Warren - 07-21-2013, 01:25 AM
RE: 47-1230 Capacitors - by Warren - 01-20-2014, 12:38 AM
RE: 47-1230 Capacitors - by Warren - 01-21-2014, 12:58 AM
RE: 47-1230 Capacitors - by Marsupial - 01-22-2014, 03:44 PM
RE: 47-1230 Capacitors - by Warren - 01-22-2014, 03:58 PM
RE: 47-1230 Capacitors - by Marsupial - 01-23-2014, 05:34 PM
RE: 47-1230 Capacitors - by Raleigh - 01-24-2014, 12:12 AM
Philco 91 Restore Code ??
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
Restoring Philco 96
There are currently 5628 online users. [Complete List]
» 1 Member(s) | 5627 Guest(s)
