Philco 118 Dial Stringing
It was the center hinged/levered fiber pulley that I removed. Going from the top to bottom pulleys was where I put the o-ring. It doesnt seem to matter for tuning that the center one is gone
Philco 118 Dial Stringing - by davemc - 07-17-2013, 04:29 PM
RE: Philco 118 Dial Stringing - by Ron Ramirez - 07-17-2013, 04:31 PM
RE: Philco 118 Dial Stringing - by davemc - 07-18-2013, 01:30 PM
RE: Philco 118 Dial Stringing - by Ron Ramirez - 07-18-2013, 01:36 PM
RE: Philco 118 Dial Stringing - by SteveJB - 07-19-2013, 11:10 AM
RE: Philco 118 Dial Stringing - by davemc - 07-19-2013, 02:45 PM
RE: Philco 118 Dial Stringing - by SteveJB - 07-20-2013, 04:27 PM
RE: Philco 118 Dial Stringing - by davemc - 07-20-2013, 05:32 PM
Philco 91 Tuning Condenser
