370 Chairside
Txn for the details on the tone control. The first one I got a previous owner drill holes in the cabinet for the off/on sw and for the tone control so this didn't have wire job for the control. The other one I got a few months ago but haven't unpacked it so haven't looked it over. Interesting system for changing the tone!
370 Chairside - by RoyG - 07-17-2013, 04:45 PM
RE: 370 Chairside - by 7estatdef - 07-17-2013, 05:53 PM
RE: 370 Chairside - by RoyG - 07-17-2013, 06:14 PM
RE: 370 Chairside - by jerryhawthorne - 07-17-2013, 07:18 PM
RE: 370 Chairside - by 7estatdef - 07-17-2013, 09:33 PM
RE: 370 Chairside - by Arran - 07-18-2013, 03:13 AM
RE: 370 Chairside - by Ron Ramirez - 07-18-2013, 05:30 AM
RE: 370 Chairside - by RoyG - 07-18-2013, 12:53 PM
RE: 370 Chairside - by Ron Ramirez - 07-18-2013, 12:54 PM
RE: 370 Chairside - by RoyG - 07-19-2013, 12:23 PM
RE: 370 Chairside - by klondike98 - 07-19-2013, 12:48 PM
RE: 370 Chairside - by jerryhawthorne - 07-19-2013, 02:12 PM
RE: 370 Chairside - by 7estatdef - 07-20-2013, 08:45 PM
Philco 91 Tuning Condenser
