Chassis & Cabinet Model ID?
Well, thanks for clearing that up Ron. The 4 bands you mentioned, are they short wave bands?
Greg
Chassis & Cabinet Model ID? - by GregL - 07-21-2013, 05:42 PM
RE: Chassis & Cabinet Model ID? - by TimC - 07-21-2013, 08:49 PM
RE: Chassis & Cabinet Model ID? - by GregL - 07-21-2013, 09:18 PM
RE: Chassis & Cabinet Model ID? - by Arran - 07-21-2013, 10:43 PM
RE: Chassis & Cabinet Model ID? - by GregL - 07-21-2013, 10:48 PM
RE: Chassis & Cabinet Model ID? - by Ron Ramirez - 07-22-2013, 05:50 AM
RE: Chassis & Cabinet Model ID? - by GregL - 07-22-2013, 06:00 AM
RE: Chassis & Cabinet Model ID? - by Ron Ramirez - 07-22-2013, 07:30 AM
RE: Chassis & Cabinet Model ID? - by Arran - 07-22-2013, 08:28 AM
RE: Chassis & Cabinet Model ID? - by GregL - 07-22-2013, 10:34 AM
RE: Chassis & Cabinet Model ID? - by Ron Ramirez - 07-22-2013, 04:08 PM
RE: Chassis & Cabinet Model ID? - by GregL - 07-22-2013, 04:20 PM
RE: Chassis & Cabinet Model ID? - by Arran - 07-22-2013, 08:46 PM
RE: Chassis & Cabinet Model ID? - by Ron Ramirez - 07-22-2013, 08:48 PM
RE: Chassis & Cabinet Model ID? - by GregL - 07-23-2013, 07:21 PM
RE: Chassis & Cabinet Model ID? - by Arran - 07-24-2013, 04:45 AM
RE: Chassis & Cabinet Model ID? - by GregL - 07-24-2013, 05:01 AM
Philco 91 Tuning Condenser
