Delco 32 volt console
I managed to find two NOS 48's and a NOS 85 today at an old TV shop in town. So, I have the hardest to find tubes for this set already. Icon_smile
Delco 32 volt console - by Jayce - 07-19-2013, 05:51 PM
RE: Delco 32 volt console - by Jayce - 07-19-2013, 09:44 PM
RE: Delco 32 volt console - by Arran - 07-20-2013, 02:01 AM
RE: Delco 32 volt console - by jerryhawthorne - 07-20-2013, 03:18 PM
RE: Delco 32 volt console - by Sean - 07-20-2013, 03:59 PM
RE: Delco 32 volt console - by Jayce - 07-20-2013, 05:09 PM
RE: Delco 32 volt console - by jerryhawthorne - 07-20-2013, 05:36 PM
RE: Delco 32 volt console - by Sean - 07-20-2013, 09:51 PM
RE: Delco 32 volt console - by Jayce - 07-21-2013, 04:48 PM
RE: Delco 32 volt console - by BrendaAnnD - 07-21-2013, 08:57 PM
RE: Delco 32 volt console - by Arran - 07-21-2013, 10:13 PM
RE: Delco 32 volt console - by codefox1 - 07-21-2013, 11:57 PM
RE: Delco 32 volt console - by BrendaAnnD - 07-22-2013, 01:51 AM
RE: Delco 32 volt console - by Jayce - 07-22-2013, 04:03 PM
RE: Delco 32 volt console - by Jayce - 09-23-2013, 09:50 PM
RE: Delco 32 volt console - by TA Forbes - 09-23-2013, 10:08 PM
RE: Delco 32 volt console - by BrendaAnnD - 09-23-2013, 11:26 PM
RE: Delco 32 volt console - by Arran - 09-24-2013, 12:51 AM
RE: Delco 32 volt console - by TA Forbes - 09-24-2013, 02:02 PM
RE: Delco 32 volt console - by marty - 09-24-2013, 02:20 PM
RE: Delco 32 volt console - by Jayce - 09-24-2013, 04:26 PM
RE: Delco 32 volt console - by marty - 09-24-2013, 05:07 PM
RE: Delco 32 volt console - by TA Forbes - 09-24-2013, 06:26 PM
RE: Delco 32 volt console - by Jayce - 09-24-2013, 07:56 PM
There are currently 6100 online users. [Complete List]
» 2 Member(s) | 6098 Guest(s)
