Restoring a restored 39-6
Does the dial pointer indicate higher than 1550, or does it mechanically stop before reaching 1700?
To me, its sounds like a case of poor mechanical adjustment and RF alignment. When you turn the tuning control to the stop at the low freq end of the dial, the pointer should be perfectly horizontal and aligned with the lines on the dial.
Restoring a restored 39-6 - by rworne - 07-22-2013, 02:51 AM
RE: Restoring a restored 39-6 - by 7estatdef - 07-22-2013, 08:51 AM
RE: Restoring a restored 39-6 - by rworne - 07-22-2013, 02:35 PM
RE: Restoring a restored 39-6 - by 7estatdef - 07-22-2013, 03:07 PM
RE: Restoring a restored 39-6 - by klondike98 - 07-22-2013, 03:37 PM
RE: Restoring a restored 39-6 - by rworne - 07-22-2013, 03:56 PM
RE: Restoring a restored 39-6 - by Mondial - 07-22-2013, 04:44 PM
RE: Restoring a restored 39-6 - by rworne - 07-22-2013, 08:47 PM
RE: Restoring a restored 39-6 - by BrendaAnnD - 07-22-2013, 09:20 PM
RE: Restoring a restored 39-6 - by rworne - 07-22-2013, 10:50 PM
RE: Restoring a restored 39-6 - by Arran - 07-23-2013, 12:47 AM
RE: Restoring a restored 39-6 - by Warren - 07-23-2013, 03:36 PM
RE: Restoring a restored 39-6 - by rworne - 07-23-2013, 06:49 PM
RE: Restoring a restored 39-6 - by Pappy B - 07-24-2013, 12:30 AM
