Philco 14 rewind coil HELP
Sure hope that there is some type of diagram out there . I want to make the coils right . Terry you are probably right , I have been looking for some kind of information on the subject for quite some time now . Have not been having to much luck though . Thanks for your input .
Philco 14 rewind coil HELP - by Old Magnum - 07-22-2013, 10:51 AM
RE: Philco 14 - by 7estatdef - 07-22-2013, 03:13 PM
RE: Philco 14 - by Old Magnum - 07-22-2013, 05:22 PM
RE: Philco 14 rewind coil HELP - by Old Magnum - 08-18-2013, 10:47 AM
RE: Philco 14 rewind coil HELP - by Ron Ramirez - 08-18-2013, 11:29 AM
RE: Philco 14 rewind coil HELP - by marty - 08-18-2013, 03:43 PM
RE: Philco 14 rewind coil HELP - by Old Magnum - 08-19-2013, 12:13 AM
RE: Philco 14 rewind coil HELP - by Old Magnum - 08-19-2013, 02:29 PM
There are currently 10436 online users. [Complete List]
» 4 Member(s) | 10432 Guest(s)
AvatarAvatarAvatarAvatar
