Philco model 42-350t
Now we just need to keep our eyes open for the proper set of knobs for Eric's 42-350t, the ones on it don't look to bad but they are obviously newer like from a 1950s radio or TV set. Here is the same set with the original knobs:
http://www.philcoradio.com/gallery/1942a.htm#p
Unfortunately they may have been made out of Tenite which may explain why they were replaced, I hate Tenite I! I think that Larry Bordanaro may make replacements if he still does that sort of thing.
Philco model 42-350t - by Eric Adams - 12-13-2012, 08:18 PM
RE: Philco model 42-350t - by Ron Ramirez - 12-13-2012, 08:22 PM
RE: Philco model 42-350t - by Eric Adams - 12-13-2012, 08:28 PM
RE: Philco model 42-350t - by Ron Ramirez - 12-13-2012, 08:36 PM
RE: Philco model 42-350t - by Eric Adams - 12-13-2012, 09:18 PM
RE: Philco model 42-350t - by Paul Philco322 - 12-13-2012, 10:05 PM
RE: Philco model 42-350t - by Eric Adams - 12-14-2012, 04:19 PM
RE: Philco model 42-350t - by Chuck Schwark - 12-14-2012, 04:53 PM
RE: Philco model 42-350t - by Ron Ramirez - 12-14-2012, 04:56 PM
RE: Philco model 42-350t - by Eric Adams - 12-14-2012, 05:06 PM
RE: Philco model 42-350t - by Ron Ramirez - 12-14-2012, 05:19 PM
RE: Philco model 42-350t - by Eric Adams - 12-14-2012, 05:30 PM
RE: Philco model 42-350t - by Eric Adams - 12-14-2012, 05:43 PM
RE: Philco model 42-350t - by kporter - 12-14-2012, 06:20 PM
RE: Philco model 42-350t - by Ron Ramirez - 12-14-2012, 09:26 PM
RE: Philco model 42-350t - by Paul Philco322 - 12-18-2012, 09:03 AM
RE: Philco model 42-350t - by Eric Adams - 12-18-2012, 11:24 AM
RE: Philco model 42-350t - by Ron Ramirez - 12-18-2012, 11:34 AM
RE: Philco model 42-350t - by Paul Philco322 - 12-27-2012, 08:51 PM
RE: Philco model 42-350t - by codefox1 - 12-30-2012, 12:48 PM
RE: Philco model 42-350t - by Chuck Schwark - 12-31-2012, 08:33 PM
RE: Philco model 42-350t - by Eric Adams - 04-25-2013, 03:33 PM
RE: Philco model 42-350t - by Steve Davis - 04-25-2013, 04:59 PM
RE: Philco model 42-350t - by codefox1 - 04-25-2013, 09:43 PM
RE: Philco model 42-350t - by Eric Adams - 04-25-2013, 10:06 PM
RE: Philco model 42-350t - by codefox1 - 07-22-2013, 12:01 AM
RE: Philco model 42-350t - by Arran - 07-22-2013, 08:52 PM
RE: Philco model 42-350t - by Eric Adams - 07-23-2013, 01:22 AM
RE: Philco model 42-350t - by Eric Adams - 07-23-2013, 02:10 PM
RE: Philco model 42-350t - by Eric Adams - 07-23-2013, 06:02 PM
Philco 91 Tuning Condenser
There are currently 9484 online users. [Complete List]
» 1 Member(s) | 9483 Guest(s)
