Zenith 5R312
Hi Brenda:
Thanks for answering. I looked at the tube socket and indeed it does say 6A8G .The bottom of chassis looks original. I'm amazed this 6K8 tube even worked, hope it didnt damage anything. Cant believed it worked with the 6K8. Anyone else have this happen?
Buzz
Zenith 5R312 - by Buzz - 07-22-2013, 07:40 PM
RE: Zenith 5R312 - by BrendaAnnD - 07-22-2013, 08:33 PM
RE: Zenith 5R312 - by Buzz - 07-22-2013, 09:11 PM
RE: Zenith 5R312 - by BrendaAnnD - 07-22-2013, 09:22 PM
RE: Zenith 5R312 - by Arran - 07-22-2013, 10:26 PM
There are currently 6329 online users. [Complete List]
» 2 Member(s) | 6327 Guest(s)
