Can you offer a solution; American Bosch chassis
I think you will be very happy with this set, as I said Northern Electric produced a clone of most of the Bosch models in the mid 1930s and they seem to be decently designed. My chassis has a replacement Hammond power transformer, which may have been a weak point in the N.E versions, but it's very similar to yours except for the band count, three verses four bands, and mine has a shadowmeter.
There are currently 7091 online users. [Complete List]
» 3 Member(s) | 7088 Guest(s)
