Restoring a restored 39-6
In the end, I'm going to have it reconed. I looked it over when I had it put fixing the tuner and the tear was actually a semicircle covering about 20-25% of the cone area.
I'm just waiting for my other radio to come in so I can do a comparison. It's got the same chassis as the 39-6.
Restoring a restored 39-6 - by rworne - 07-22-2013, 02:51 AM
RE: Restoring a restored 39-6 - by 7estatdef - 07-22-2013, 08:51 AM
RE: Restoring a restored 39-6 - by rworne - 07-22-2013, 02:35 PM
RE: Restoring a restored 39-6 - by 7estatdef - 07-22-2013, 03:07 PM
RE: Restoring a restored 39-6 - by klondike98 - 07-22-2013, 03:37 PM
RE: Restoring a restored 39-6 - by rworne - 07-22-2013, 03:56 PM
RE: Restoring a restored 39-6 - by Mondial - 07-22-2013, 04:44 PM
RE: Restoring a restored 39-6 - by rworne - 07-22-2013, 08:47 PM
RE: Restoring a restored 39-6 - by BrendaAnnD - 07-22-2013, 09:20 PM
RE: Restoring a restored 39-6 - by rworne - 07-22-2013, 10:50 PM
RE: Restoring a restored 39-6 - by Arran - 07-23-2013, 12:47 AM
RE: Restoring a restored 39-6 - by Warren - 07-23-2013, 03:36 PM
RE: Restoring a restored 39-6 - by rworne - 07-23-2013, 06:49 PM
RE: Restoring a restored 39-6 - by Pappy B - 07-24-2013, 12:30 AM
There are currently 9782 online users. [Complete List]
» 2 Member(s) | 9780 Guest(s)
