Restoring my 37-116. It plays now!
Threads: 562
The silicon grommet that holds back shaft of the tuning cap dried out.
Does anyone sell exact fitting grommets?
RE: Restoring my 37-116. The tuning cap grommer back shaft grommet - by morzh - 07-23-2013, 09:53 PM
Users browsing this thread: 38 Guest(s)
Quick progress report:
Hi Rod,
Hello Tim,
Hello Tim,
There are currently 9885 online users. [Complete List] » 2 Member(s) | 9883 Guest(s)
