  • 2 Vote(s) - 5 Average
Philco model 18 (code 121) - HELP!
To test whether a new choke will solve your problem, you can use a 250 ohm 10 watt resistor in place of it. If the set comes to life, or at least starts giving voltage where it currently is not, then you can figure on replacing it. You should be able to get a replacement from AES.
There are a couple different lamps used for the shadow meter. If it's the screw in type, you would use a #46. If it's a snap-in type, you can use a #46 or 44.
RE: Philco model 18 (code 121) - HELP! - by morzh - 02-07-2013, 10:22 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 02-08-2013, 10:32 PM
RE: Philco model 18 (code 121) - HELP! - by Arran - 02-08-2013, 10:49 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 02-09-2013, 02:21 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 02-09-2013, 05:57 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 02-09-2013, 06:12 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 02-13-2013, 08:40 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 02-21-2013, 05:25 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 02-28-2013, 06:04 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 03-07-2013, 04:16 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 03-07-2013, 11:20 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 04-17-2013, 01:25 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 04-18-2013, 08:48 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 04-18-2013, 09:49 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 04-29-2013, 10:02 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 06-12-2013, 01:37 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 06-13-2013, 08:33 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 07-23-2013, 10:33 PM
RE: Philco model 18 (code 121) - HELP! - by BrendaAnnD - 07-23-2013, 10:34 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 07-24-2013, 11:11 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 08-02-2013, 05:06 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 08-21-2013, 10:26 AM
RE: Philco model 18 (code 121) - HELP! - by morzh - 12-17-2013, 10:58 AM
RE: Philco model 18 (code 121) - HELP! - by morzh - 12-19-2013, 12:47 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 12-19-2013, 08:48 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 01-17-2014, 04:05 PM
Users browsing this thread: 13 Guest(s)
Philco 91 Tuning Condenser
