38-12 Code 121 Tube Dilemma
If it has a 6A8, then somebody replaced the original 7-pin socket with an octal socket.
The 6A7 and 6A8 are electrically identical, but as mentioned above, the 6A7 requires a 7-pin standard socket, while the 6A8 requires an octal socket.
38-12 Code 121 Tube Dilemma - by Buzz - 07-24-2013, 04:11 PM
RE: 38-12 Code 121 Tube Dilemma - by Ron Ramirez - 07-24-2013, 04:44 PM
RE: 38-12 Code 121 Tube Dilemma - by BrendaAnnD - 07-24-2013, 04:47 PM
RE: 38-12 Code 121 Tube Dilemma - by Ron Ramirez - 07-24-2013, 04:50 PM
RE: 38-12 Code 121 Tube Dilemma - by Buzz - 07-24-2013, 04:52 PM
RE: 38-12 Code 121 Tube Dilemma - by codefox1 - 07-24-2013, 08:08 PM
There are currently 8639 online users. [Complete List]
» 1 Member(s) | 8638 Guest(s)
