40-190 hums intermittently
I was referring to a chassis ground inside the set. Is the hum 60 Hz or 120 Hz?
40-190 hums intermittently - by fossilexpress - 07-23-2013, 11:50 PM
RE: 40-190 hums intermittently - by fossilexpress - 07-24-2013, 10:04 AM
RE: 40-190 hums intermittently - by BrendaAnnD - 07-24-2013, 11:58 AM
RE: 40-190 hums intermittently - by fossilexpress - 07-24-2013, 04:17 PM
RE: 40-190 hums intermittently - by BrendaAnnD - 07-24-2013, 04:48 PM
RE: 40-190 hums intermittently - by Mondial - 07-24-2013, 08:02 PM
RE: 40-190 hums intermittently - by fossilexpress - 07-24-2013, 08:48 PM
RE: 40-190 hums intermittently - by fossilexpress - 07-24-2013, 09:32 PM
RE: 40-190 hums intermittently - by vinzer - 07-24-2013, 10:29 PM
RE: 40-190 hums intermittently - by fossilexpress - 07-24-2013, 10:34 PM
RE: 40-190 hums intermittently - by BrendaAnnD - 07-24-2013, 10:42 PM
RE: 40-190 hums intermittently - by klondike98 - 07-24-2013, 10:43 PM
RE: 40-190 hums intermittently - by fossilexpress - 07-24-2013, 11:08 PM
RE: 40-190 hums intermittently - by Phlogiston - 07-25-2013, 12:30 AM
RE: 40-190 hums intermittently - by fossilexpress - 07-25-2013, 01:10 AM
RE: 40-190 hums intermittently - by codefox1 - 07-25-2013, 09:45 AM
RE: 40-190 hums intermittently - by Raleigh - 07-27-2013, 02:02 PM
RE: 40-190 hums intermittently - by codefox1 - 07-28-2013, 12:29 PM
RE: 40-190 hums intermittently - by fossilexpress - 08-01-2013, 06:31 PM
