Philco model 18 (code 121) - HELP!
City: Sedona, AZ/Placentia/CA
Dang Pith, this thing is going backwards. On prior posts you were getting some sound out of the speaker and now your getting no voltages anywhere? Not having worked on this model but it really sounds if you don't have the speaker plugged in. The speaker with it's field coil allows the B+ voltage to continue to the set. If your meter is set to DC and you get no voltage on the plates of any of the tubes, either the speaker is not plugged in or it's field coil is bad.
After that nice vacation, and all that relaxation, did you forget to do that?
Jerry
RE: Philco model 18 (code 121) - HELP! - by jerryhawthorne - 07-24-2013, 05:49 PM
Users browsing this thread: 36 Guest(s)
Philco 91 Tuning Condenser
I thought you meant the actual dial....there are rivets.morzh — 08:42 PM |
This is what I meant.morzh — 08:37 PM |
Here are the links. 6TPZ and 5TPO
The speakers are good. I've tried several known good ones. I just have to fi...R3Sons — 06:27 PM |
I just found a set screw. Was able to turn dial just enough to see it and loosen it. I have it off now.dconant — 06:14 PM |
Hello,
Does anyone know how the dial plate comes off the tuning condenser shaft? The dial itself id so warped I can't...dconant — 06:01 PM |
Ron,
for the future:
1. Go to the very first post.
2. Hit "Edit...morzh — 04:29 PM |
Transistors are easy.
Or touch your fin...morzh — 04:25 PM |
Hi Mike, I believe I tried different ways to change the header for my post but no luck. Anyway thanks for changing it fo...462ron — 04:02 PM |
Since these radios operated in harsh environments (temp changes and vibration) you could touch a soldering iron to all t...GarySP — 03:18 PM |
Thank you Gary. Hi Morzh. These radios are 6 transistor radios. Sadly no tubes. Thanks though.R3Sons — 02:19 PM |
There are currently 9153 online users. [Complete List] » 1 Member(s) | 9152 Guest(s)
