Hello All: First Time User! Help with 37-84
you can get a new dial here http://www.oldradioparts.net/dials_intro.html
and new knobs at http://www.renovatedradios.com/parts.html#knobs
just scroll down to the philco hex knobs
maybe someone else can tell you if the correct grill cloth can be found if not what is in the radio was used in some 37 models.
RE: Hello All: First Time User! Help with 37-84 - by vinzer - 07-24-2013, 06:38 PM
There are currently 4378 online users. [Complete List]
» 4 Member(s) | 4374 Guest(s)
AvatarAvatarAvatarAvatar
