I.F. coil bypass - Sort of like a heart bypass
Marty, I would say #1 is a good start. After that if it doesn't work, post a WTB in the classified for the transformer. You did not give much information as to what the radio model is, that would really help. A lot of people out here that have parts that can help you. I would not proceed to #2 or #3 until such time as I would either see if I can fix it or then find another transformer.
Jerry
RE: I.F. coil bypass - Sort of like a heart bypass - by jerryhawthorne - 07-25-2013, 06:57 PM
There are currently 9318 online users. [Complete List]
» 3 Member(s) | 9315 Guest(s)
