Philco 623
Budi, that radio does have a very complex power supply, not like many that had a simple 90V and 1.5V requirement. Those were easy to build or use batteries. Yours requires a large variations of voltages and some high (130V) not really in line to adding a lot of batteries, without a very expensive power supply (from those that build them) not an easy radio to get up running. My best advice is if you like that radio, use it as a nice accent piece for your house but not try to make it work. Sorry but just my opinion.
Jerry
Philco 623 - by budibower - 07-24-2013, 09:53 PM
RE: Philco 623 - by 7estatdef - 07-25-2013, 08:11 AM
RE: Philco 623 - by codefox1 - 07-25-2013, 09:54 AM
RE: Philco 623 - by klondike98 - 07-25-2013, 02:13 PM
RE: Philco 623 - by 7estatdef - 07-25-2013, 05:11 PM
RE: Philco 623 - by jerryhawthorne - 07-25-2013, 07:08 PM
RE: Philco 623 - by Ron Ramirez - 07-25-2013, 07:15 PM
RE: Philco 623 - by jerryhawthorne - 07-25-2013, 07:25 PM
RE: Philco 623 - by 7estatdef - 07-25-2013, 08:51 PM
RE: Philco 623 - by marty - 07-25-2013, 09:17 PM
RE: Philco 623 - by 7estatdef - 07-25-2013, 09:37 PM
RE: Philco 623 - by marty - 07-25-2013, 09:52 PM
RE: Philco 623 - by jerryhawthorne - 07-25-2013, 10:20 PM
RE: Philco 623 - by budibower - 07-25-2013, 10:28 PM
RE: Philco 623 - by budibower - 07-25-2013, 10:38 PM
RE: Philco 623 - by marty - 07-25-2013, 11:29 PM
RE: Philco 623 - by Arran - 07-26-2013, 08:16 AM
RE: Philco 623 - by marty - 07-26-2013, 09:30 AM
RE: Philco 623 - by 7estatdef - 07-26-2013, 12:13 PM
RE: Philco 623 - by Bob Andersen - 07-26-2013, 02:30 PM
RE: Philco 623 - by budibower - 07-26-2013, 09:21 PM
There are currently 9047 online users. [Complete List]
» 1 Member(s) | 9046 Guest(s)
