I.F. coil bypass - Sort of like a heart bypass
Hi All;
Thank You All, Mondial, I have opened it up, and as carefully as I could under a magnifying glass, looked at and moved the wires, a little.. The wires to the caps are fine..
In a way I would prefer number 1, but I am afraid of unwinding it all and not having that funny way of winding it back and would then be totally out of Luck with this coil.. As winding it back straight round and round would not be the same..
THANK YOU Marty
RE: I.F. coil bypass - Sort of like a heart bypass - by marty - 07-25-2013, 08:51 PM
