41-250 No sound, glowing 41 tube, can't be a good thing
Hi justlrnin. Before you go any further have you run voltage readings per the schematic? Tubes can appear different because of their physical make up. I'm not saying you don't have a problem but you can only determine that by voltage checks. PL
PS: Before the voltage tests, did you do resistance checks on the various components, particularly the primary of the output transformer?
[No subject] - by Harlan - 02-19-2008, 10:03 PM
[No subject] - by planigan - 02-20-2008, 12:34 AM
[No subject] - by justlrnin - 02-20-2008, 02:10 AM
[No subject] - by planigan - 02-20-2008, 03:21 AM
[No subject] - by Terry Judkins - 02-20-2008, 07:21 AM
[No subject] - by planigan - 02-20-2008, 02:08 PM
[No subject] - by Ron Ramirez - 02-20-2008, 06:51 PM
[No subject] - by justlrnin - 02-20-2008, 11:06 PM
[No subject] - by Ron Ramirez - 02-20-2008, 11:20 PM
[No subject] - by justlrnin - 02-27-2008, 03:18 PM
[No subject] - by rghines1 - 02-27-2008, 05:35 PM
[No subject] - by justlrnin - 02-27-2008, 07:33 PM
[No subject] - by Doug K. - 02-27-2008, 08:32 PM
[No subject] - by rghines1 - 02-27-2008, 08:50 PM
[No subject] - by FStephenMasek - 05-09-2008, 07:44 PM
There are currently 4217 online users. [Complete List]
» 3 Member(s) | 4214 Guest(s)
