38-3 Dial question
grayrabbit, the dial scale may be warped. See if you can put one of the self adhesive felt dots in a place where it will not wipe over the printing, blank area. That should hold it away from fitting but not wear off printing.
PL
38-3 Dial question - by gary rabbitt - 02-18-2008, 04:34 PM
[No subject] - by Ron Ramirez - 02-18-2008, 07:33 PM
[No subject] - by gary rabbitt - 02-18-2008, 08:15 PM
[No subject] - by BDM - 02-19-2008, 01:54 AM
[No subject] - by gary rabbitt - 02-19-2008, 02:57 PM
[No subject] - by planigan - 02-20-2008, 12:53 AM
[No subject] - by gary rabbitt - 02-21-2008, 03:02 AM
[No subject] - by planigan - 02-21-2008, 02:08 PM
[No subject] - by gary rabbitt - 02-22-2008, 01:33 AM
[No subject] - by planigan - 02-22-2008, 01:13 PM
[No subject] - by gary rabbitt - 02-22-2008, 06:31 PM
There are currently 11418 online users. [Complete List]
» 2 Member(s) | 11416 Guest(s)
