Capacitor voltages
Planning on a total recap of a 40-190. Some of the capacitors have already been replaced, don't know if correctly. I went to the list of replacement parts, and with the exception of two "Electolytic cond." (Parts #58 and #61), the voltages are not given. They generally read something like "Tubular cond. (.05 mfd)".
Based on a previous thread, should I just get all of these as 600 volts?
BTW. Will also be replacing all of the resistors, as recommended.
Thanks - Roy
Capacitor voltages - by fossilexpress - 07-26-2013, 02:51 PM
RE: Capacitor voltages - by Raleigh - 07-26-2013, 03:18 PM
RE: Capacitor voltages - by fossilexpress - 07-26-2013, 03:48 PM
RE: Capacitor voltages - by Raleigh - 07-26-2013, 05:27 PM
RE: Capacitor voltages - by codefox1 - 07-28-2013, 12:24 PM
RE: Capacitor voltages - by fossilexpress - 08-01-2013, 10:58 PM
RE: Capacitor voltages - by BrendaAnnD - 08-01-2013, 11:11 PM
RE: Capacitor voltages - by fossilexpress - 08-01-2013, 11:34 PM
RE: Capacitor voltages - by morzh - 08-02-2013, 09:24 AM
Philco 630csx power cord
Let's try to sort it out. So we are working with the same info here's the schematic I have: ...and here's the pin o...klondike98 — 09:03 PM
I posted this on FB but knowing that not all of us use social media, it seemed sensible to ask my question here.  I r...Tynwald — 08:07 PM
Philco 40-155
At last, got this working well. Impressed has really nice reception and tone. Had a bad connection on one of the capaci...rogerh — 07:44 PM
Philco 91 Restore Code ??
Or you could just square the current :lol: As for the values, they are dependent on the 1 or 2-speaker system. The...morzh — 05:46 PM
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
There are currently 2504 online users. [Complete List]
» 2 Member(s) | 2502 Guest(s)
