Philco Hippo Speaker
tony2K35, hi. When you make up the list of caps check it twice for values. Radio Daze has a minimum order and I know a guy that had to order three times as he kept on screwing up on a .001mfd (.1mfd one time, .01mfd the next) so he had to order more then he needed. Well, ended up with a large selection of caps ($15.00 worth of spares)! PL
[No subject] - by Guest - 02-03-2008, 03:30 PM
[No subject] - by Ron Ramirez - 02-03-2008, 04:22 PM
[No subject] - by Guest - 02-18-2008, 10:42 AM
[No subject] - by gary rabbitt - 02-18-2008, 04:25 PM
[No subject] - by planigan - 02-20-2008, 01:04 AM
There are currently 8900 online users. [Complete List]
» 2 Member(s) | 8898 Guest(s)
