can anyone identify this model
http://www.philcoradio.com/gallery/1940c.htm#h
But, it should have only one toggle switch under the left side of the dial, not two toggle switches!
That is one of my favorite Philco consoles. Very neat styling, and a very good performer as well, once you deal with the usual rubber-covered wiring issues.
can anyone identify this model - by sionnain - 07-26-2013, 09:57 AM
RE: can anyone identify this model - by Ron Ramirez - 07-26-2013, 05:03 PM
RE: can anyone identify this model - by sionnain - 07-26-2013, 05:21 PM
There are currently 6935 online users. [Complete List]
» 4 Member(s) | 6931 Guest(s)
AvatarAvatarAvatarAvatar
