41-250 No sound, glowing 41 tube, can't be a good thing
Good call, Planigan. The output transformer tests open (it looks like garbage is growing in it). As for the filament voltage--it is right where it should be at 6.3v. I'll look for a replacement transformer (any suggestions where to buy one?) and move on to the next issue from there.
Thanks.
[No subject] - by Harlan - 02-19-2008, 10:03 PM
[No subject] - by planigan - 02-20-2008, 12:34 AM
[No subject] - by justlrnin - 02-20-2008, 02:10 AM
[No subject] - by planigan - 02-20-2008, 03:21 AM
[No subject] - by Terry Judkins - 02-20-2008, 07:21 AM
[No subject] - by planigan - 02-20-2008, 02:08 PM
[No subject] - by Ron Ramirez - 02-20-2008, 06:51 PM
[No subject] - by justlrnin - 02-20-2008, 11:06 PM
[No subject] - by Ron Ramirez - 02-20-2008, 11:20 PM
[No subject] - by justlrnin - 02-27-2008, 03:18 PM
[No subject] - by rghines1 - 02-27-2008, 05:35 PM
[No subject] - by justlrnin - 02-27-2008, 07:33 PM
[No subject] - by Doug K. - 02-27-2008, 08:32 PM
[No subject] - by rghines1 - 02-27-2008, 08:50 PM
[No subject] - by FStephenMasek - 05-09-2008, 07:44 PM
Philco 91 Tuning Condenser
There are currently 8501 online users. [Complete List]
» 2 Member(s) | 8499 Guest(s)
