Philco 47-1230 Resto Advice Needed
Check out this web site for a beginner's approach to restoring radios: Phil's Old Radios at antiqueradio.org . Mr. Nelson's site has just about everything you need to read to get started. It was a major help to me when I was working on my first couple of radios.
John Honeycutt
Philco 47-1230 Resto Advice Needed - by uncleray - 07-23-2013, 07:00 AM
RE: Philco 47-1230 Resto Advice Needed - by Raleigh - 07-27-2013, 02:07 PM
