The Emerson is singing now
Threads: 88
City: Tacoma
http://www.esrcvacuumtubes.com/vacuumtub...lasts.html
They have the L49B, which is the same thing but with a tap for only one pilot lamp. I haven't found anyone yet that has the L49BG for two lamps.
Note: the K49B is a similar single lamp ballast, but requires use of a #47 lamp rather than the #46.
RE: An Emerson like this one - by BrendaAnnD - 07-27-2013, 04:02 PM
Quick progress report:
Hi Rod,
Hello Tim,
There are currently 3855 online users. [Complete List] » 1 Member(s) | 3854 Guest(s)
