Your opinions, please...
Hi Bill
Good to hear from you.
$36 is not a bad price at all, especially if you want to keep the set. If you're looking to resell, though, you won't break even - you'll never be able to get the $$$ back in terms of the time it takes to replace all of that rubber insulation on the wiring (or replace the wires with new). Randal also noted this point.
Your opinions, please... - by Bill Hutchinson - 02-19-2008, 02:47 PM
[No subject] - by Texasrocker - 02-20-2008, 12:18 AM
[No subject] - by Ron Ramirez - 02-20-2008, 08:04 AM
[No subject] - by Bill Hutchinson - 02-22-2008, 06:13 PM
[No subject] - by Ron Ramirez - 02-22-2008, 07:52 PM
[No subject] - by Texasrocker - 02-23-2008, 03:24 AM
Philco 91 Tuning Condenser
