37-620 Tuner Dishwasher Safe?
I usually soak the unit in a bucket of Extreme Green parts cleaner and hot water. I'll let it soak for a day or so and then use a toothbrush. Rinse with hot water and then use a blow dryer to dry it out completely, then lube the bearings.
Good luck with your project!
Kevin
37-620 Tuner Dishwasher Safe? - by Vic Gibson - 07-28-2013, 10:33 AM
RE: 37-620 Tuner Dishwasher Safe? - by codefox1 - 07-28-2013, 12:13 PM
RE: 37-620 Tuner Dishwasher Safe? - by Vic Gibson - 07-28-2013, 12:33 PM
RE: 37-620 Tuner Dishwasher Safe? - by 37silverstreak - 07-28-2013, 03:32 PM
RE: 37-620 Tuner Dishwasher Safe? - by GarySP - 07-29-2013, 09:00 PM
RE: 37-620 Tuner Dishwasher Safe? - by morzh - 07-30-2013, 09:06 AM
RE: 37-620 Tuner Dishwasher Safe? - by marty - 07-30-2013, 09:33 AM
RE: 37-620 Tuner Dishwasher Safe? - by BrendaAnnD - 07-30-2013, 10:40 AM
RE: 37-620 Tuner Dishwasher Safe? - by codefox1 - 07-30-2013, 10:55 AM
RE: 37-620 Tuner Dishwasher Safe? - by marty - 07-30-2013, 01:06 PM
RE: 37-620 Tuner Dishwasher Safe? - by Vic Gibson - 07-30-2013, 05:22 PM
RE: 37-620 Tuner Dishwasher Safe? - by BrendaAnnD - 07-30-2013, 09:01 PM
RE: 37-620 Tuner Dishwasher Safe? - by Mondial - 07-30-2013, 09:17 PM
RE: 37-620 Tuner Dishwasher Safe? - by codefox1 - 07-30-2013, 09:49 PM
RE: 37-620 Tuner Dishwasher Safe? - by Vic Gibson - 07-31-2013, 02:36 PM
RE: 37-620 Tuner Dishwasher Safe? - by codefox1 - 07-31-2013, 09:23 PM
There are currently 9598 online users. [Complete List]
» 1 Member(s) | 9597 Guest(s)
