Model 38-3 Volume Control
I had my model 38-3 radio recapped recently. It plays very well but it seems that there is an issue with the volume control. When I turn the volume control fully counter clockwise to the minimum volume setting the radio does not mute. A few times when I turn the volume clockwise to increase the volume the volume will increase but most of the time the volume actually decreases a bit. This does seem to be intermittent but again most of the time the volume control doesn't adjust the volume level. It seems to remain at a constant level. What should I check to see if I can correct the volume control?
Charlie
Model 38-3 Volume Control - by cwirth - 07-29-2013, 10:02 AM
RE: Model 38-3 Volume Control - by codefox1 - 07-29-2013, 01:55 PM
RE: Model 38-3 Volume Control - by BrendaAnnD - 07-29-2013, 03:12 PM
RE: Model 38-3 Volume Control - by codefox1 - 07-29-2013, 07:56 PM
Philco 40-155
At last, got this working well. Impressed has really nice reception and tone. Had a bad connection on one of the capaci...rogerh — 07:44 PM
Philco 91 Restore Code ??
Or you could just square the current :lol: As for the values, they are dependent on the 1 or 2-speaker system. The...morzh — 05:46 PM
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
There are currently 2611 online users. [Complete List]
» 6 Member(s) | 2605 Guest(s)
AvatarAvatarAvatarAvatar
