Link to thread about restoring original finishes?
This was a thread dealing with worn finishes. Basically going over a worn fish with new coats of toner and lacqer topcoats as opposed to stripping and refinishing. It is a good thread, I just can't find it again!
There are currently 6997 online users. [Complete List]
» 4 Member(s) | 6993 Guest(s)
AvatarAvatarAvatarAvatar
