The Emerson is singing now
#40
In the meantime another question:
first, maybe Ron could move this into the "Other radios" - the trend seems to turn into the restore discussion. Or at least part of it.
Second,
I do not have a source other than Nostalgiaair, and it has no parts locations diagram.
If someone knows where to find it, or what volume Rider's describes it, I have the Rider, but it is too much to search if you don't know what and where you are searching for.
Main question for today:
Cap C30 ( the one from the 25L6's cathode to GND) is listed as 5uF in the parts list.
In my chassis there is a small molded cap that clearly cannot be 5uF.
The soldering seems factory.
If anyone has this or similar radio using 25L6, could you look what it uses there in place of C30?
The Emerson is singing now - by morzh - 07-22-2013, 10:07 PM
RE: An Emerson like this one - by BrendaAnnD - 07-23-2013, 02:48 AM
RE: An Emerson like this one - by morzh - 07-23-2013, 07:17 AM
RE: An Emerson like this one - by Arran - 07-23-2013, 08:08 AM
RE: An Emerson like this one - by morzh - 07-23-2013, 08:33 AM
RE: An Emerson like this one - by morzh - 07-23-2013, 08:37 AM
RE: An Emerson like this one - by Phlogiston - 07-23-2013, 09:36 AM
RE: An Emerson like this one - by morzh - 07-23-2013, 03:37 PM
RE: An Emerson like this one - by Phlogiston - 07-23-2013, 05:06 PM
RE: An Emerson like this one - by Arran - 07-24-2013, 04:53 AM
RE: An Emerson like this one - by morzh - 07-24-2013, 01:44 PM
RE: An Emerson like this one - by Phlogiston - 07-24-2013, 02:23 PM
RE: An Emerson like this one - by morzh - 07-24-2013, 08:26 PM
RE: An Emerson like this one - by Phlogiston - 07-24-2013, 09:09 PM
RE: An Emerson like this one - by Arran - 07-26-2013, 11:36 AM
RE: An Emerson like this one - by morzh - 07-26-2013, 06:23 PM
RE: An Emerson like this one - by morzh - 07-26-2013, 07:39 PM
RE: An Emerson like this one - by Paul Philco322 - 07-26-2013, 08:50 PM
RE: An Emerson like this one - by morzh - 07-26-2013, 09:27 PM
RE: An Emerson like this one - by morzh - 07-26-2013, 09:44 PM
RE: An Emerson like this one - by morzh - 07-26-2013, 10:00 PM
RE: An Emerson like this one - by morzh - 07-26-2013, 10:08 PM
RE: An Emerson like this one - by Mondial - 07-26-2013, 10:19 PM
RE: An Emerson like this one - by Phlogiston - 07-26-2013, 10:20 PM
RE: An Emerson like this one - by morzh - 07-27-2013, 01:06 PM
RE: An Emerson like this one - by BrendaAnnD - 07-27-2013, 04:02 PM
RE: An Emerson like this one - by BrendaAnnD - 07-27-2013, 04:16 PM
RE: An Emerson like this one - by morzh - 07-28-2013, 12:31 AM
RE: An Emerson like this one - by BrendaAnnD - 07-28-2013, 04:18 AM
RE: An Emerson like this one - by morzh - 07-28-2013, 09:11 PM
RE: An Emerson like this one - by BrendaAnnD - 07-28-2013, 10:11 PM
RE: An Emerson like this one - by morzh - 07-29-2013, 09:17 PM
RE: An Emerson like this one - by morzh - 07-30-2013, 10:05 AM
RE: An Emerson like this one - by BrendaAnnD - 07-30-2013, 10:51 AM
RE: An Emerson like this one - by morzh - 07-30-2013, 03:28 PM
RE: An Emerson like this one - by morzh - 07-30-2013, 08:18 PM
RE: An Emerson like this one - by morzh - 07-30-2013, 08:33 PM
RE: An Emerson like this one - by BrendaAnnD - 07-30-2013, 09:06 PM
RE: An Emerson like this one - by morzh - 07-30-2013, 09:41 PM
RE: An Emerson like this one - by morzh - 07-30-2013, 09:56 PM
RE: An Emerson like this one - by BrendaAnnD - 07-30-2013, 10:43 PM
RE: An Emerson like this one - by morzh - 07-30-2013, 11:11 PM
RE: An Emerson like this one - by morzh - 07-30-2013, 11:29 PM
RE: An Emerson like this one - by Phlogiston - 07-31-2013, 12:25 AM
RE: An Emerson like this one - by Ron Ramirez - 07-31-2013, 05:27 AM
The Emerson - it is singing now. - by morzh - 07-31-2013, 10:57 AM
RE: An Emerson like this one - by Phlogiston - 07-31-2013, 04:28 PM
RE: An Emerson like this one - by BrendaAnnD - 07-31-2013, 07:10 PM
RE: An Emerson like this one - by Phlogiston - 08-01-2013, 01:09 AM
RE: An Emerson like this one - by BrendaAnnD - 08-01-2013, 02:30 AM
RE: An Emerson like this one - by morzh - 08-01-2013, 09:41 AM
RE: An Emerson like this one - by Gene Pederson - 08-06-2013, 05:39 PM
RE: An Emerson like this one - by morzh - 08-13-2013, 11:41 PM
RE: An Emerson like this one - by Paul Philco322 - 08-14-2013, 09:10 PM
RE: An Emerson like this one - by morzh - 08-15-2013, 01:54 PM
RE: An Emerson like this one - by Paul Philco322 - 08-15-2013, 02:28 PM
RE: The Emerson is singing now - by morzh - 08-17-2013, 10:15 PM
RE: The Emerson is singing now - by morzh - 08-18-2013, 11:56 PM
RE: The Emerson is singing now - by morzh - 09-16-2013, 10:43 AM
RE: The Emerson is singing now - by Radioroslyn - 09-16-2013, 02:21 PM
RE: The Emerson is singing now - by morzh - 09-16-2013, 03:23 PM
Users browsing this thread: 15 Guest(s)
There are currently 4898 online users. [Complete List]
» 3 Member(s) | 4895 Guest(s)
