Hello All: First Time User! Help with 37-84
I believe klondike's link to the gallery shows originality but I once owned this 37-84 with a different cloth which I believe was original also. Either one would be fine IMHO.
RE: Hello All: First Time User! Help with 37-84 - by Art Hoch - 07-31-2013, 04:53 PM
There are currently 10613 online users. [Complete List]
» 3 Member(s) | 10610 Guest(s)
