Hello All: First Time User! Help with 37-84
Toby, I believe you did quite well on the price, particularly without having it shipped to you. Enjoy it and the restoration. Don't tell your wife but I suspect like most of us, when it is playing you will be looking for more radios. I find it a much cheaper hobby than many and very enjoyable. How many rounds of golf could you buy for that price? And think that radio will be with you for a long time. Great hobby.
Jerry
RE: Hello All: First Time User! Help with 37-84 - by jerryhawthorne - 07-31-2013, 07:04 PM
There are currently 10608 online users. [Complete List]
» 1 Member(s) | 10607 Guest(s)
