Ballast Tube
Well, you were right. No continuity at all. I opened it up just to see what it looked like and found broken wires inside. Has anyone put resistors inside the metal tube instead of replacing it?
Eric
The Villages, FL
Ballast Tube - by Eric Adams - 07-31-2013, 06:13 PM
RE: Ballast Tube - by BrendaAnnD - 07-31-2013, 07:12 PM
RE: Ballast Tube - by Eric Adams - 07-31-2013, 08:27 PM
RE: Ballast Tube - by morzh - 07-31-2013, 08:44 PM
RE: Ballast Tube - by BrendaAnnD - 07-31-2013, 09:18 PM
RE: Ballast Tube - by Eric Adams - 07-31-2013, 09:24 PM
RE: Ballast Tube - by Eric Adams - 07-31-2013, 10:38 PM
RE: Ballast Tube - by Eric Adams - 07-31-2013, 10:48 PM
RE: Ballast Tube - by BrendaAnnD - 08-01-2013, 12:08 AM
RE: Ballast Tube - by Eric Adams - 08-01-2013, 12:51 AM
