Capacitor voltages
If we are to trust the sch the voltage across 61 is 270V and across 58 - 185V.
Now granted that is working loaded voltage and it can go up to 40% up if unloaded, and this is why we want some margin on the WV plus the margin for derating, so where it is 270V I would use 450V cap, sure. 600V will take all the questions out.
1000V? Total overkill. 1600V? More overkill.
Capacitor voltages - by fossilexpress - 07-26-2013, 02:51 PM
RE: Capacitor voltages - by Raleigh - 07-26-2013, 03:18 PM
RE: Capacitor voltages - by fossilexpress - 07-26-2013, 03:48 PM
RE: Capacitor voltages - by Raleigh - 07-26-2013, 05:27 PM
RE: Capacitor voltages - by codefox1 - 07-28-2013, 12:24 PM
RE: Capacitor voltages - by fossilexpress - 08-01-2013, 10:58 PM
RE: Capacitor voltages - by BrendaAnnD - 08-01-2013, 11:11 PM
RE: Capacitor voltages - by fossilexpress - 08-01-2013, 11:34 PM
RE: Capacitor voltages - by morzh - 08-02-2013, 09:24 AM
There are currently 5370 online users. [Complete List]
» 1 Member(s) | 5369 Guest(s)
