Philco 39-45 hums on some stations
My 39-45 hums on stations from about 800- 1710. Below about 800, the audio is nice and clear. Above 800, there is an annoying hum behind the station's audio. It does not occur in the SW bands, just the mid-to-upper BC band.
Any ideas?
Philco 39-45 hums on some stations - by Eric T - 08-03-2013, 10:53 AM
RE: Philco 39-45 hums on some stations - by marty - 08-04-2013, 03:34 PM
RE: Philco 39-45 hums on some stations - by marty - 08-17-2013, 01:40 PM
There are currently 10476 online users. [Complete List]
» 2 Member(s) | 10474 Guest(s)
