Shadow meter question
If the rf side had a bad coil the radio wouldn't work...right?
Possibly the alignment? Once my output coil comes in I'll check it out. Thanks for the suggestions. This is the first shadow meter I've found that is still working.
Marty.....I had a few "shocking" experiences when I was a kid. After I blew a bunch of fuses in the house trying to re-wire a record player I was "convinced" by dad and the repeated near electrocutions to quit.
Shadow meter question - by Groundhog74 - 08-01-2013, 09:00 PM
RE: Shadow meter question - by BrendaAnnD - 08-01-2013, 10:37 PM
RE: Shadow meter question - by AI2V - 08-02-2013, 11:05 AM
RE: Shadow meter question - by morzh - 08-02-2013, 02:52 PM
RE: Shadow meter question - by marty - 08-02-2013, 10:14 PM
RE: Shadow meter question - by Groundhog74 - 08-03-2013, 05:59 PM
RE: Shadow meter question - by BrendaAnnD - 08-03-2013, 07:17 PM
RE: Shadow meter question - by morzh - 08-03-2013, 08:06 PM
Philco 630csx power cord
Let's try to sort it out. So we are working with the same info here's the schematic I have: ...and here's the pin o...klondike98 — 09:03 PM
I posted this on FB but knowing that not all of us use social media, it seemed sensible to ask my question here.  I r...Tynwald — 08:07 PM
Philco 40-155
At last, got this working well. Impressed has really nice reception and tone. Had a bad connection on one of the capaci...rogerh — 07:44 PM
Philco 91 Restore Code ??
Or you could just square the current :lol: As for the values, they are dependent on the 1 or 2-speaker system. The...morzh — 05:46 PM
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
There are currently 2410 online users. [Complete List]
» 2 Member(s) | 2408 Guest(s)
