Philco grommets
Hmmm...being too tired to look it up in detail, I would say all 1938 models EXCEPT Models 38-12, 38-14, 38-15, 38-33, 38-35, 38-93.
What, are you about to go into production of these, or something? Icon_biggrin
Blacksmith (Renovated Radios) already offers the 1936 grommets...
http://www.renovatedradios.com/parts.html
Philco grommets - by BDM - 02-23-2008, 09:17 PM
[No subject] - by Ron Ramirez - 02-23-2008, 11:27 PM
[No subject] - by BDM - 02-23-2008, 11:33 PM
[No subject] - by Ron Ramirez - 02-23-2008, 11:48 PM
[No subject] - by BDM - 02-24-2008, 12:09 AM
[No subject] - by Texasrocker - 02-26-2008, 11:35 PM
[No subject] - by BDM - 02-27-2008, 12:24 AM
[No subject] - by Texasrocker - 02-28-2008, 01:16 AM
[No subject] - by BDM - 02-28-2008, 01:24 AM
[No subject] - by Texasrocker - 02-28-2008, 03:19 AM
[No subject] - by BDM - 02-29-2008, 12:32 AM
[No subject] - by Texasrocker - 02-29-2008, 04:49 AM
Philco 91 Tuning Condenser
There are currently 9852 online users. [Complete List]
» 1 Member(s) | 9851 Guest(s)
