power Transformer
Why not just leave it?? The 5u4 is an easier tube to get than the 5X4.
power Transformer - by vinzer - 08-04-2013, 05:02 PM
RE: power Transformer - by 7estatdef - 08-04-2013, 06:30 PM
RE: power Transformer - by vinzer - 08-04-2013, 06:34 PM
RE: power Transformer - by codefox1 - 08-05-2013, 11:29 AM
RE: power Transformer - by vinzer - 08-05-2013, 04:13 PM
RE: power Transformer - by BrendaAnnD - 08-05-2013, 04:35 PM
RE: power Transformer - by vinzer - 08-05-2013, 04:46 PM
RE: power Transformer - by codefox1 - 08-05-2013, 05:08 PM
RE: power Transformer - by vinzer - 08-05-2013, 06:41 PM
There are currently 9488 online users. [Complete List]
» 2 Member(s) | 9486 Guest(s)
