Restoring my 37-116. It plays now!
Threads: 268
Well Mike it's almost time to sit down and relax in a comfortable easy chair next to your 37-116. These set can make an AM station sound like FM because of the wide bandwidth. That's what the treble control will do. Short of a lighting storm they sound great!!
Enjoy it tonight!!!
RE: Restoring my 37-116. It plays now! - by 7estatdef - 08-04-2013, 07:00 PM
Quick progress report:
Hi Rod,
Hello Tim,
Hello Tim,
There are currently 3202 online users. [Complete List] » 1 Member(s) | 3201 Guest(s)
