O man now I've done it, Philco 37-116
We are all here for you. Finished one for a friend (38-116) and murf is right, it is a bit of a challenge but nice sounding radio when done. Now we need some pictures which all of us like!
Jerry
RE: O man now I've done it, Philco 37-116 - by jerryhawthorne - 08-04-2013, 07:54 PM
There are currently 9667 online users. [Complete List]
» 3 Member(s) | 9664 Guest(s)
