O man now I've done it, Philco 37-116
City: Sedona, AZ/Placentia/CA
Ron, very nice looking cabinet, hopefully little to do other than some good cleaning and a wax. Fine looking radio but a lot of work to recap. As indicated, take your time.
Jerry
RE: O man now I've done it, Philco 37-116 - by jerryhawthorne - 08-04-2013, 09:25 PM
Users browsing this thread: 14 Guest(s)
Quick progress report:
Hi Rod,
Hello Tim,
Hello Tim,
There are currently 10238 online users. [Complete List] » 3 Member(s) | 10235 Guest(s)
